Switch Lever Prototype
Switch Lever Prototype Files
You cannot view this attachment.
These files may be difficult to print with an FDM printer - a nozzle 0.3 mm or smaller is recommended, as the curved body of the design is extremely thin. It is probably better to consider printing these in resin instead.
Note: the switches available on AliExpress already have the lever and it is only necessary to print your own if you want period-correct colouring.
AliExpress -> Momentary Action Switches
AliExpress -> SPDT switch
Here's the problem I had slicing this model for FDM printing. Resin may be the best option.
